frustratedboater
- Jul 10, 2007
- 489
I have a vintage 1957 Evinrude 7.5 hp motor, model #7522, that is quitting completely after 23-25 seconds of wide open throttle. I can putter around with even slight throttle and runs very well and smooth, but as soon as I bring it past that, the motor boggs down, and quits. It will start with a very short choke pull when pull-started.
I have gone through the carb 4 times with the same results. The carb has a new kit on it, needle packing, etc.. I had blown out the low fuel circuit and also the center of the bowl and out through the fixed jet, and also the center bowl jet is clean. I have even looked through (with light) to make sure that my high speed needle is unobstructed and clear. I took the dime shaped plate on the top where the low speed needle intersects and the low fuel circuit is clean through out.
Am I missing something? I am usually pretty solid with these small carbs, but this one really has me! Every possible passageway is blown out with air and is clear. Is there something, or somewhere else I should be checking? Any assistance would be appreciated.
~FB~
~FB~
