- Jul 18, 2011
- 18,285
Since I am going to be buying some fiberglass and resin materials for my bulkhead and Stringer replacement project, http://forums.iboats.com/showthread.php?t=534913 I am wondering if there will be an advantage to use vinyl ester resin to adhere to the hull and existing fiberglass surfaces.
I believe that the moisture resistance is better with vinyl ester versus polyester, but I am not sure if there is an advantage for adhesion. Also, not sure about strength differences between the 2.
T.I.A. for your advice.
