jkimball
- May 14, 2013
- 220
Wanted to see if anyone has any experience with Viper Stainless props.
I have a '99 FW Horizon 170 with a Johnson 115. Recently I changed props from the original beat up 19p aluminum that came with the boat to an OMC 17p stainless and gained ~500 rpms (went from 4,900 to 5,400-5,500 WOT) and about 4-5 MPH top end (went from 38-43/44 MPH) all while having an awesome hole shot.
So, I got to thinking that since I saw such an improvement with a 17p stainless, I wonder what kind of results I would have with going back to the OEM pitch size of 19p but in stainless since it has less flex and generally nets more rpms than a comparable aluminum.
I ran across a good deal on a 19p OMC Viper Stainless, and got it for $79 shipped. I got the prop today and it's in great shape, hub looks good and no nicks or dents on the leading edges or tips. So for $79... not bad!
I just want to see what the general consensus is. I've heard good and bad of these props. I know I'll likely lose some hole shot and some rpms WOT, but I should still be in the "safe zone" on WOT rpms as the manufacturer states 4,500-5,500 is acceptable.
All things consistent, since I noticed a top speed increase from going down 2" of pitch switching to stainless, is it reasonable to assume that I'll notice an even greater increase on top speed returning to a 19p stainless? Or will bringing the rpms back down to around ~5,000 cancel this out and I'll break even with what I'm netting on the 17" wheel?
