Volt meter hook up
Rich Novak
1972 SLICKCRAFT 225 HP STERNDRIVE
I want to add a volt meter to my current gauges.
Do I just run a wire from the + side of the gauge to the Ignition switch, and the - side to ground ??
Sounds to easy to me
Thanks, Rich
Don S
Re: Volt meter hook up
That is all there is too it. From the ign. switch I terminal to the + post on the meter and the - terminal on the meter to ground.
Silvertip
way simpler to connect to the same "I" terminal and ground on the closest gauge. Do the same for the internal light.
