2003 DF140.
My battery was several years old and left me stranded on the lake, so I replaced it. I checked some voltages and now I'm not sure it's just the battery that was the problem.
The new battery before starting is about 12.3 volts. When I start the motor, it jumps to 14.4 or so at any RPM which I think is perfect. But when I turn on the nav lights while still running, (one small bulb in front and back and the dash lights) the voltage drops to about 13.5 and stays there. Shouldn't it still charge in the 14.4 range, no matter what I turn on? Should I suspect some trouble with the rectifier/regulator? I read a post that claims if the tach works, which it does, there's likely nothing wrong with the charging coil. Thanks for any suggestions.
