Voltage Issues
lcmains1
Well, It seems like I have another issue. 1990 mercruiser 5.0lx
I took my boat out Friday evening and noticed that the voltage gauge was reading about 11 volts. I thought that seemed odd as it is normally reading between 12-14 volts. It has been fluctuating for the past couple of months (dont know why)
The boat ran fine and I had no issues BUT by the end of the night it was reading just below 11 volts.
When I got home Friday night i pulled the battery and plugged it into the tricle charger. When I plugged it in it said it was fully charged....Hmmmmmm..... So I left it on the charger overnight anyway.
I put the battery back in the boat Sunday and it read about 11 volts again. I ran for about 5 hours on Sunday with some tubing and skiing. Some of the time the gauge would read 14 volts and when I put it back on the trailer it was reading 10 volts. What in the Hell??:facepalm:
So I pulled the battery again and also pulled the altranatorto get them both tested. I am guessing that the alt is going bad?? Does that seem right?
Also, does the gauge measure the battery voltage itself or is it measuring the output of the altranator? :confused::confused::confused:
Thanks for the help in advance
Don S
Re: Voltage Issues
Get a DVM (Digital Volt Meter) and check the voltage. You may just have a bad gauge.
lcmains1
Re: Voltage Issues
The output of the altrenator is good...Measured 60 amps. Battery is also good after being tested.
I have a belt that has been squeeling on and off, just have not replaced it yet. Could that cause it?
Don S
Re: Voltage Issues
CobiaXL
Banned
Re: Voltage Issues
weak belts will cause alt.to not charge.Get a digital volt meter to check voltage output at alt.
