voltage problems, alternator upgrade?
sunnygrill
I have a 1977 mercury outboard 115 hp L6 and I just put in a pretty powerful stereo system. I took it out to the lake and the first day I had not really a problem but the second day the marine optima had enough. I dont think the motor is supplying enough juice to the battery, so what can I do to solve my problem? Thanks.
Scali
Re: voltage problems, alternator upgrade?
maybe a bigger battery, youve got to be carefull because not all Mercs hve voltage regulators { @ least mine doesnt 1994 40 } .<br />I was checking my voltage output just yesterday & it's 17.5 volts @ idle.<br />That may not be good for a stereo, guess you'd just end up with a blown fuse though maybe ..
Chris1956
Sunny, That motor has an unregulated ~6 Amp charging system. The battery load will generally keep the voltage under 14V. I would check to make sure the battery is being charged by the motor. The easy way to do this is to put a DC voltmeter on the battery, note the voltage and then start the motor. If the voltage rises as the rpm rises, it is charging.
briannh1234
I think it's really a 12 amp charging system. But if your running a big stero off it and the motor is not charging the battery enough then you need a new source of power.<br /><br />I would recommend that when you are not using your boat that you get a smart charger and plug it in. Optima batteries are real picky about their chargers - look for one that claims to be optima compatable.
sunnygrill
chris, I'll check that but when the battery would get really low I would turn off the radio for a while and the battery did charge but with the stereo on it just drains the battery. Now I have a second battery for back up, but what can I do to to illiminate this problem? What would you do?Thanks.
Chris1956
Sunny, If the charging system plus the battery cannot supply the stereo, there are only three things you can do. One is to get a generator, which is impractical. Two - don't listen to the stereo, also impractical. Three - use a battery isolator and associated wiring such that your stereo and other accessories run off their own deep cycle battery. Have the motor starting battery only start and run the motor.<br /><br />Let me say this. I would really look into the amperage draw of your stereo. Even a 15 Amp draw by a stereo (which is a lot) shouldn't affect a charged battery, if you are listening to the stereo on a day boating trip. if you anchor overnight and burn lights also, that is a different story.
briannh1234
Sunny -<br /><br />For your other source of power I would suggest using a smart charger before you go out boating. This will store the power you will need in the battery. The problem with the smart charger is you need a place to plug it in when the boat is not being used. I keep my boat on my trailer so it's not a big deal for me. But if you keep your boat in the water you may want to look into one with the word "Marine" on it as well as "Optima".<br /><br />Most boat charging systems will not completely recharge the battery on a short run. You will need to run the motor for hours to truly recharge the battery.
