Voltage regulator for 1960 Johnson 40hp with Prestolite generator
corvair kid
I need a voltage regulator for my '60 RDSL-22-C.It has a prestolite generator.(well,it will have if I can find a regulator!)no luck from ARCO&NAPA.I also need a drive belt.Thanks!
Lark40
Re: Voltage regulator for 1960 Johnson 40hp with Prestolite generator
I believe that it is a common Ford regulator. Used to buy mine at any auto parts store. Bring in the old one and it can be matched up with a reference book.<br /><br />AS of a couple of years sgo, the gen belts were available through jonhson/Evinrude dealers for about $50.
rolmops
Lark is right.<br />That is what mine is.
corvair kid
Many,many thanks BillH!Featherweight had exactly what I was looking for!They are rather pricy but if you're gonna play,you gotta pay!Thanks again!
Lark40
Why pay a lot when you could have bought the exact same item at your nearest auto parts store?
corvair kid
Couldn't find it at any auto parts store.They didn't have any listing for a 10 amp,12 volt regulator.
bhalsdorf
NAPA here didn't have one either. The closest they had wouldn't mount into my junction box either. Besides the closest they had was a 20 amp and the older motors use a 10 amp.
corvair kid
I have aquired an original OMC generator kit.It has everything I need! I appreciate all the input! Thanks very much!
Ohioangler
Ditto for me Kid<br /><br />Good Luck
