Voltage regulator/rectifier needed 40AMP water cooled
PRdiver
Hello Boaters:
I'm in search of a voltage regulator/rectifier 40 Amps Water Cooled. It is for a Mercury 150 Black Max serial 0C27xxxx. The stator I have is two (2) yellow cables. If one of you have a good working one or know where to find it. PLEASE, let me know.
Thanks in advance,
PRdiver
Chris1956
Re: Voltage regulator/rectifier needed 40AMP water cooled
CDI Electronics likely carries them. Sometimes you replace a single 40A regulator with duel 20 A regulators. I don't think the Merc VRs were watercooled, at least not directly.
sschefer
Hello Boaters:
Thanks in advance,
PRdiver
I think I've got one in the shop. I'll take a look tonight when I get home and let you know. I know I have at least one good 40amp. Are you converting from a 16 to a 40?
PRdiver
Nop, my system is 40 amps already. Do you know if I can replace that regulator by another one 40 amps?
the wiring diagram is attached
sschefer
I just went through my stash box and I have three 16 amp. I thought I had a 40 but not so. I must have given it to someone.
I always upgrade to the 4 wire stators and use dual rectifier/regulators. CDI sells a complete kit and Merc sells a block off plate for your exhaust divider.
sschefer
It was buggin me so I dug through a couple of more boxes and found another one. I labeled it when I took it off a 40 amp motor and it has the same part number as the other ones. I guess they're all the same. So I either have 4 16's or 4 40's.
PM me if you really want one. I can't guarantee the condition since these things were known to get really hot and fail often. You may be just getting another headache.
Faztbullet
I got a new one and used one like you need...:D
j_martin
If it's water cooled, it's 40 amp. 16 amp had the little 3 post rectifier on the switchbox mounting plate.
sschefer
Cool then I have 4 40 amp water cooled rectifier/regulators. Whooopie! Maybe I can shine them up and make paperweight Xmas gifts out of them.
j_martin
If they're good, and you clean them up and put em on eBay, they're gold.
Faztbullet
Hey Steve if yours has the part number 815279-x they are the 16/40 amp models as they are dual purpose.(see 1st pic below) He has the "divider plate" style(2nd pic). I doubt you have any engines old enough that came with the "Divider style" rec/reg and if you do they are worth $250 each used.
