Voltage Regulator
mike6868
Why are there really cheap ($35) and really expensive ($150>) voltage regulators on the market? They both look the same on the outside? I had two cheap ones fail in the past year. I went ahead a bought an expensive regulator. I hope this is a good case of "you get what you pay for"
The Force power
I think you answered your own question
Quality & amps output are a factor
sam am I
https://www.amazon.com/LActrical-REC...ct_top?ie=UTF8
94% 5 Star
03% 4 Star
"You purchased this item on July 17, 2016"
The two I bought back then ^^^^ are still good to go and are very well used........I run 3 batts (two deeps, one starting) 4 electric downrigger, bilge, wash down, live well, fish well, Garmin, VHF, Standard AM/FM, yada yada yada and never had an issue yet with them.
You might have some other issues esp since you have a mod'd system AND/OR you do have to be careful with some knock off stuff out there, however these are the real deal.........I'm fairly confident CDI is buying from same'ish Chinese source, re-branding and marking them waaaay up.
The Force power
https://www.amazon.com/lactrical-rec...ct_top?ie=utf8
94% 5 star
03% 4 star
"you purchased this item on july 17, 2016"
the two i bought back then ^^^^ are still good to go and are very well used........i run 3 batts (two deeps, one starting) 4 electric downrigger, bilge, wash down, live well, fish well, garmin, vhf, standard am/fm, yada yada yada and never had an issue yet with them.
You might have some other issues esp since you have a mod'd system and/or you do have to be careful with some knock off stuff out there, however these are the real deal.........i'm fairly confident cdi is buying from same'ish chinese source, re-branding and marking them waaaay up.
agreed!
BTL
So far no problems with the cheapo I bought last year for a 1992 Mariner 150.
