I have a 1996 225 EFI Mercury Offshore, that runs ok...noticed the voltmeter guage showing less than 13 (Which is half of gauge, which goes from 8-18) when key is on, and when engine is running does not go up, goes down. Tested battery, was low, put on charger and hydrometer tested over 1200, battery appears good although both batteries are 7 years old. Does gauge indicate charging problem, if so HOW DO I CHECK ALTERNATOR OUTPUT TO INSURE THAT IS WHERE PROBLEM IS? or WHAT ELSE SHOULD I CHECK FOR A CHARGING PROBLEM? I have a small solar panel plugged in occassionally to ciggarett lighter, would that affect charging system?
