Bart Sr.
- Jul 26, 2002
- 1,603
Hi guys...I was going to take the boat out for the first time yesterday so I got the battery off the shelf in the basement and hooked it up.Got nothing but clicks.Hooked up the charger on quick start and waited 15 minutes as per unit instructions and still nothing.Hooked up the jumper cables and got it running but after running for 15 minutes at 1200 RPMs there was only enough power to trim a few times and start a few times.So I hooked the charger on trickle and tried after work today.It started fine and ran fine but the VOLTMETER IS PEGGED at 18.<br /><br />Anyway I must be suffering from CRS because I'm wondering about the battery cable connections.Mainly the two smaller ones.One red and one black.I connected red to positive and black to ground.Is this correct???????<br />Could this cause the meter to be pegged????????<br /><br />Thanks in advance>>Bart Sr.
