Voltmeter vs alt output
peter555
Please help I own a Merc 5.0 and the volt meter reads 10 v steady when idle and at 2k rpm. I have a dual battery system. Am I looking at a volt meter problem or is alt failing. Thank you.
Peter
alldodge
Might be a bad boat meter but the easy determination is with a hand held volt meter.
Place meter probes on the Bat and see if boat meter matches hand held
Ayuh,...... My guess is, the charging system should be investigated,.....
Could be bad gauge, connections, alternator or all the above
Start trouble shooting with a DVM
nola mike
10v and you wouldn't be starting or (most likely) running. Like AD said, check voltage at the battery. If it's good you probably have bad connections at the helm
ROY WILLIAMS
Peter
THE VOLTMETER VOM ELECTRONIC TOOL .. VOLT 13.75 -14.75 VDC ...ON THE ALTERNATOR POSITIVE ...
THE ALTERNATOR REGULATOR DIODES IS THE DAMAGED IT ..
