Hey guys
Im moving along wiring up my gauges. Got a new tach and fuel guage and got them working. I also got a votmeter guage so I can check the battery is while the engine is running.
Seems like I have a couple of options for wiring up the gauge.
1. pull a hot and neutral directly from the battery and switch the hot leg.
2. Tap off the purple wire which should be the stator wire,
3. Connect a jumper wire off the bat terminal on the fuel gauge thats right next the volt meter.
4. tap off the ignition switch.
Im alittle confused about the voltage regulator.. Seems it would do exactly what its called regulate the voltage to to dash components. So does it lower the voltage to the ignition and the gauges to 12 v if so it wouldnt give an accurate reading if the generator is charging.
