broncojeff78
- May 31, 2012
- 61
So i finally fixed the overheating problem on my 230b and now its on to the next one. It will start and run fine but every once in a while in starts to stumble when you let off the throttle and acts like it starving for fuel. If you stay at cruising speed its usually fine until you let off. It will idle fine but wont take any throttle for a while. If it sits for a while and then start it up again to go its fine then happens again. I took the carb apart a little and cleaned the bowl out thinking there was some crud in there but it was pretty clean. I installed a fuel water separator which didnt change anything but I thought it would be better than the cheesy glass fuel filter with a screen inside that it had. Is my fuel pump on its way out? Any ideas?
