Volvo 250
MABOATS
Hi There,
I am trying to find out if a Volvo AQ250 leg with similar ratio is compatable and able to be hooked up to a AQ280 unit utilising the existing bell housing and transom setup.
The leg on the AQ280 is dead. cheers
Don S
Re: Volvo 250
You will have problems with the steering fork and helmet assembly and getting the proper attaching setup for the 250 drive.
The 250 uses a single pin/screw to hook the helmet to the upper gear box. The 280 probably has the pin and two bolts holding it in.
