volvo 270 outdrive, what happened?
Char259
On the river yesterday everything goin fine. I hear a clank and the engine shuts off. The starter tries to turn the engine over but cant. I pulled the sparkplugs, look fine. The engine oil looks fine too. I check the outdrive oil, It was low. While checking, I notice when you turn the key to try and start, the outdrive jolts. When your turn the wheel, the engine turns over slightly. What could the problem be?
whywhyzed
Banned
Re: volvo 270 outdrive, what happened?
Sounds like gears and bearings piled up in the outdrive. Remove outdrive and see if engine cranks over, or get a shop to do it.
olbuddyjack
Might be the u-joints too. Either way the drive has to come off. Good luck with the pins.
bruceb58
You can take off the upper gear housing seperately. That way the whole drive doesn't have to come off.
