Glastron_V210
- Jan 28, 2009
- 324
Hi all.
I was looking for some stiff steering on my 285. I found it.
First I removed all the internal steering connections up to the steering fork (I have cable steering), so there was no internal resistance. I found the drive was still stiff back and forth. I disconnected the steering helmet in preparation to remove the drive and found the leg itself is really nice and loose.
So, the sticking is where the steering shaft comes through from the steering lever to the steering fork/helmet.
So, to remove the fork/helmet, my manual says to:
1) Remove tiller arm set screw using 5/32 allen key (Turned out it was a 9/16 headed screw...perhaps it's been changed
2) Pry the steering fork down from the transom shield (on the outside)
Well, she is stuck....any advice??? Anything I missed?
Thanks,
Chay
Thanks,
Chay
