New to the group. 2000 Volvo 3.0 runs great except idle won't go below 900 in gear. Occasionally diesels at shut down. Will be doing a tune up on the weekend and would like to know if I should adjust the idle mixture ( carb still has the plastic caps on the idle mixture screws ) or leave as is. I'm also unsure of when to apply 12volts to the adaptor plug on the distributor when timing the engien. Is it before starting the engine or after. Should I suspect an intake manifold leak ? Is it also necessary to use an external tach to verify the RPM ?
