Good morning all. Own a 1998 Glastron 185 FS. This carries a 4.3gl Volvo Penta IO. Engine ID 4110168702.
Ok so current issue is... I replaced fuel pump 2 weeks ago because when replacing the livewell aerator I knelt on the plastic connector and cracked it off. (So difficilt to get your body in there to work on things!)
Symptoms are...it will start and run good at 1st. Then after a couple hours when I throttle up to take off it will just bog out and die.
After it dies, impossible to restart. This has happened out on the lake now several times and is boggling to me.
It cranks and seems to want to fire but no fuel. Pump accelerator and no fuel from jets. The fuel pump is running when key key turned to start as I can feel it.
Takes over an hour sometimes to get it going, but eventually it will.
Not overheating, at less than 200 when this happens.
When it is working I get fuel when exercising the accelerator, and runs great. But no fuel spraying into carb after this happens.
Im thinking of just replacing the fuel pump with a better one? Bought a cheaper replacement off Amazon.
what could or should I check? I took off and reinstalled all fuel lines and connections from tank to carb and saw / felt no restrictions or debris.
Thanks for any input in advance.
