West Islander
- Jun 29, 2020
- 7
Several weeks ago my boat unexpectedly stopped on the water as I was throttling back. I determined I wasn’t getting spark ( grounded a spark plug I pulled) and got towed to shore I trailered home And hooked it up to a trickle charger. The next day I checked the purple wire at the coil and had battery voltage (12.64). I hit the key and the boat fired right up ( I didn’t do anything other than hook it to a trickle charger... basically it fixed itself on the tow home).
I used the boat several. Other times and it ran great. Today I went out and it was running fine. I was idling and power drifting, occasionally bumping it from neutral into reverse. I moved the throttle and it died. I had my multi meter with me in case this happed So I could try diagnose ing the problem... with the key in the on position I had 12.6 volts at the purple wire feeding the coil, 12.5 volts at the pink wire going to the rear of the distributor. I checked the engine ground by placing the positive lead onto the positive terminal of the battery and the ground prob to the exhaust riser. It showed 12.5 volts..... when I tried placing a screw driver in the spark plug wire and grounding it seeing if I got a spark to jump there was nothing...... I don’t have a MOB tether on this boat... clearly something is associated with the throttle that kills it yet I’m still getting good voltage to the coil....what am I missing
