allingeneral
- Aug 26, 2008
- 81
My port engine started having an issue with back-firing through the intake when under load near the end of last season with about 750 hours of runtime. I replaced a bunch of stuff before finally doing a compression test and determining that #2 cylinder was pushing zero compression.
So, I got the head off today, and found that the #2 intake valve has "tuliped" or "mushroomed". Presumably from too much heat in that cylinder for various reasons, but I can't identify which reason would be the most likely culprit. That discussion is probably for a separate thread.
My question has to do with replacing the valves. VP wants almost $100 each for the intake valves - this is ridiculous. $790 for 8 intake valves? Are these people insane? Where can I find the valves for a better price? VP part number seems to be 3857666. Where can I find proper valve dimensions?
I think I'm going to take the head to get the #2 intake valve seat ground. Should I get them all done? Should I pull the other head off and replace them as well? I'm leaning toward just replacing the intake valves on the problem side and leave the rest of it alone, slap it all back together and run it.
What do you think?
What do you think?
