Volvo 5.0GX1 Fuel Pump
moorish
I need help/advice please. I own a 24foot Daycruiser (Vintage Sunseeker Mexico 24). I fitted a new engine a few year ago (Volvo Penta 5.0 GXi). When complete I started the engine and it run well for a few minute and stopped. I then realized I had left the fuel valve on the off position. I turned it on and after a few tries the engine started ok. My question is that after using the boat for a few years I am not convinced that it delivering it max power. For a 280hp engine and a boat that weighs approx 5000lbs it should be nearing the 45knts mark. It has never gone over 34knts even with a clean hull.
I remember reading in the Engine Installation guide that it could damage the fuel pump if the engine is run with the fuel valve shut. The engine starts and accelerates smoothly it just that the speed/power is not there.
Don S
Re: Volvo 5.0GX1 Fuel Pump
What is your max WOT (wide open throttle) rpm? What outdrive and gear ratio do you have?
Maclin
I think 35 knots in a 24 footer with a 5.0 is not too bad. That is almost 40mph. The drive ratio of 1.78 seems too high to me for a 5.0 though, seems like that is big-block ratio territory. What propset are you running?
Don S
1.78 is for the big blocks, you should have a 1.95:1 ratio for a 5.0 or 5.7 . Especially with a 5.0.
You may get the rpm in range by changing props, but you will loose top end. Probably have a weak hole shot too.
