Volvo 5.7Gi-E running rich
chrishick
Hello everyone,
I've got a new problem that just started a few weeks ago. I'm pretty sure the engine is running rich. Here is what I know so far.
1) The transom has black soot on it after a day on the water.
2) The engine idles smooth, but has a shake when on the earmuffs at 1500-2000 rpms.
3) The engine runs smooth when in the water and under load.
4) Twice now I've been coming up on a plane with the engine running around 3000rpm and it will start to lose rpm's and backfired a few times. Come to idle and then slowly accelerate again and no problems.
5) When flushing the engine there will be an oily sheen on the water and a lot of black soot.
I just replaced the fuel pump 3 weeks ago, but the problem started before that. I did take it to a dealer last week but they could find nothing wrong with it. I believe they checked the fuel pressures and did a code scan, but I'm not sure. I did have a leaking raw water pump that was spraying the engine with salt water, so I'm thinking bad sensor or corroded electrical connection of some sort. My service manual makes mention of checking for items that will cause the engine to run rich, but then leaves you hanging by not telling you what those items are.
The engine is a 2005 fuel injected and the serial # is 4012150295.
Anybody have an ideas on where to start troubleshooting this thing?
Don S
Re: Volvo 5.7Gi-E running rich
What service manual do you actually have? The OEM manual?
chrishick
<<<BUMP>>>
Anybody?
That's the only downside to these forums. So much great information, but there is sooooo much traffic that your posts get buried in the blink of on eye.:(
Don S
No, I think it is Seloc.
No wonder you have problems. First you are going to need OEM manuals. Here are links to them.
EFI Diagnostic = http://www.4shared.com/file/83596359/cdacddfb/7742218_EFI_Diagnostics.html
Engine = http://www.4shared.com/account/file/74506321/9da18d5d/7743372_Engine_Manual_50-57.html
You are also going to need a diagnostic computer to see what is going on.
Here is a great tool, that will really do every thing you need, at an affordable price.
http://www.rinda.com/marine/mtspec.htm
Along with a DVM and a fuel pressure gauge for EFI systems and you will be set to troubleshoot your system.
chrishick
Wow! Thank you so much Don. These are great. Looks like I've got a LOT of reading to do. So much more information than the Seloc book. This actually tells you what each sensor does and how it works.
Two questions.
I don't see a place to purchase the scan tool on the Rinda site and google is not much help. Where to purchase and how much do they cost?
Do you have any other Volvo manuals you can share with me? I like doing my own maintenance and repairs and like to think I'm a decent shade tree mechanic. Any other info would be of great use.
Thanks
