Volvo 8.1 Power Steering Pressure Question
dennison17
I have a 2004 Cobalt 240, 8.1 Volvo with power steering. I had to replace the steering "actuator" this year because fluid was leaking from a seal on one end of the actuator.
I notice that each time I run the engine, a small of pressure (I would guess a few pounds) builds up in the power steering system. I have been cracking the cap to the pump after use to release that pressure because I don't want to replace that actuator again. Any thoughts as to if the pressure build up is normal.... and if releasing the pressure is a good idea?
Re: Volvo 8.1 Power Steering Pressure Question
Ayuh,... I believe the Cap is Vented... or supposed to be...
dennison17
Hmmmm, thanks for the comment on the "vented" cap... I'll have to check on that....but I believe it's original equipment.
Hmmm, I guess I can also call the dealer for any thoughts. Appreciate your comments!!
