MikeCaldwell
- Apr 20, 2015
- 14
Boat Techs out there, question.. As short as possible, harness shorted out against pipe and killed boat, took points and coil with it. rewired everything , all good, new power distribution blocks with meters for 12+ and for Neg. New coil , points, condenser, fuel pump, rebuilt carb, everything looking good. Compression check around 170 on each cylinder, Set Piston 1 to TDC on compression stroke and marks lined up and made sure Distributor had points fully open and the rotor o...n Cylinder. So off we went. Started the boat.. Finally started up but each time about 5 seconds and then shutdowns like its being starved of something, kept trying things until the starter sheared off a pin in the starter gear so the little gear just spins. Ordering a starter now to get here this week.
Big question before I get this new starter in. Any help or idea why it keeps starting and dies would be appreciated? I can't help to think its a blocked port in the Carb or Carb related. New plug wires on the way. Ideas? Volvo Penta AQ120B / 270 Stern 4 cyl, points (still trying to the electronic working).. Thanks ahead!
