Volvo Aquamatic 250 lift motor wiring question.
Guidi
Hello, my lift motor will only go down. When I try to lift the motor I just get a click. I took it apart and cleaned all
the connections. The wires and ends are all new, but before I put it back I want to be sure it is wired correctly.
Attached is a diagram of the wiring. The colors may be incorrect because it looks like it was re-wired before.
I would appreciate someone who is familiar with this unit to give it a look so I can
re-install it with confidence. Also, the Hartmann F-49 limit switch housing broke. I can probably epoxy it back together
but wanted to check with all you forum experts to see if you know where I may be able to get one. I searched google with
no luck. All input is appreciated.
