Hi All
Our electrical issues seem to be continuing on a Volvo D3-220.
We had problems with lifting and lowering the leg, we got the leg down and launched the boat. It started and went into gear ok.
We then turned off the engine and then came back a couple hours later, batteries were off.
It will now not start, click, turn over, all gauges are blank onscreen. We get "EVC error, see op manual" Our EVC is key start
I have checked all connections, disconnected the battery, unplugged and plugged in all connectors.
I think the PCU may have failed as I cant lift of lower the leg, the engine will not turn over, its just dead. I have tried the throttle setup, reboot of EVC etc.
I am in the Virgin islands and both technicians for the Virgin Islands are off with sick leave.
Can anyone shed any light on what to do or try. I am trying to get the technician out with the Volvo Computer to do a diagnostic. I have sent my error codes to volvo 24/7 and they said to get a technician. They dont know what to do.
Error codes:
MID 164
PSID 218
FMI 9
MID 164
SID 264
FMI 9
MID 164
PSID 99
FMI 12
Is there a way to bridge a relay to get the leg lifted so I can get the boat our of the water. If so, which relays are they. I have 2 relays on the aft bulkhead which may be the ones to bridge but I am unsure. The engine control for the drive leg isnt doing anything.
Thank you
Mark
Error codes:
MID 164
PSID 218
FMI 9
MID 164
SID 264
FMI 9
MID 164
PSID 99
FMI 12
Thank you
Mark
