Volvo DP drain plug fitting
low timer
Hello, I'm looking to purchase a drain plug fitting to change the drive lube. I plan to convert a garden sprayer to pump the fluid into the drive, but I haven't located a fitting to screw into the drain plug. Any suggestions would be appreciated.
Thanks
Don S
Re: Volvo DP drain plug fitting
So, what kind of DP drive is it? Volvo has several versions of the DP.
Thalasso
Thanks
By the time your done converting you can buy the proper pump online for around $10.00 plus shipping. The adapter will cost you more.
low timer
What is the best place to buy the pump? I've seen the pumps which fit on the oil container, but read these take 15-20 min to pump 2.5 quarts. I would like to find a pump that will last more than a couple of times.
Thanks for your suggestions.
