Volvo duo prop locking nut identification
Blackbamboot
Anybody recognize this locking nut brand? Lost the key!
bruceb58
First thing I would do is get rid of that locking nut and put on a regular nut.
GA_Boater
This shows what a waste prop locks are, screwdriver, hammer and vice grips.
I normally weld the outer sleeve to the inner section on the locks, then weld a nut to the top of the sleeve then use a wrench to remove
I have also driven in a few screws and used a vice grip
Screw drivers and vice grips didn't even budge the bolt so I ended up having to TIG a nut onto the recessed locking bolt. It’s out
I have done about 30 wheels like that, however only 2 props
