Re: Volvo Duo Props Size and Gearing
What ratio do you have now? 1.98 or 2.3 ? Is this the first time you have run this boat with that engine? What speed are you at when 5000rpm is reached? Also what size boat is this in.
It would be good to know what it was propped with before the engine mods, and what rpm and top speed so we could have some kind of a baseline to compare to.
My SWAG is.....I figure you must have the 2.3 to be at the place you are now. The B series goes to B8, with 1.75-2 inch pitch change for each step. If the engine is as free to rev as you state, and it has the 2.3 ratio, then I think a gear swap to the 1.95 is in order. Need to get a feeling for the torque curve, though the smaller the boat the less it will be a factor. Does it jump out of the hole now? Or does the engine need to work at it just for a second or so? If the power band is up higher in the RPM range and it is a "big" boat the 2.3 ratio and higher pitch props may be better, to keep from lugging out of the hole.
