I bought a 2006 Crownline LS early this summer that has a 5.0 Volvo in it. A few weeks ago I started noticing that when I started the boat the engine sounded rough and vibrated. I looked at the engine and notice that the steering mechanism behind the motor was moving rapidly back and forth causing the movement that I felt. After about 20 seconds it usually comes out of it. If I shut the engine off and restart then it starts just fine. It's always on the initial start. Yesterday, I noticed a slight whine in the engine and also noticed my oil pressure was down to almost nothing when idling. When cruising the oil pressure seemed normal. Also yesterday, when I initially started cruising the engine cut out momentarily twice. I didn't have to restart though. It's like it just momentarily lost power. I've been noticing a gas slick in the water when I pull the plug lately as well. I'm not sure if it is related but wanted to throw that out there. My initial thought is that my oil pump may be going bad. I have a short video of what the engine is doing but wasn't able to upload it. I could email it to someone if it was helpful . Any thoughts would be appreciated!
