Ok need help:
I have an 2006 25.6ssi
My motor trim started to not work only in the down position. The up position works as it should. I have cleaned contacts, checked fuses, replaced relay and have replaced switch in the throttle control. I seems when pump is cold or sits for awhile it works fine , but if using the trim and switch then it stops working only in the down position. Trim fluid levels are also good. I can't figure it out. Any help would be appreciated thank you. It's a volvo penta out drive.
