pianorealm
- Jun 2, 2005
- 28
Hi. Really struggling here.
Bought the engine (exc. cond) as a runner but not pumping water. I've stripped down the pump casing and replaced the impellors (2) two rotary shaft seal and the gaskets. STILL won't pump water.
I've checked the obvious....no obstructions on the inlet side & the pipe/water jacket on the delivery side seem clear. Although I've not pressure tested the block, the engine starts 1st time so I imagine there are no cracks.
The impellor casing comes in two identical halves with an impellor in each. One for the cooling system and one which goes to a bilge pump, (not connected).
Does anyone have any experience on these engines. I'm thinkling maybe it's been messed with in the past and not assembled correctly. In particular, there is a stainless plate/gasket that seperates the two pump casings. This has only one hole drilled trhough for water to pass and I'm thinking maybe it should have two? Just a guess but any help would be appreciated. I've been on this on and off now for months and I'm supposed to be using the boat/engine on hols next week!
Desperate!!!
Howard
Desperate!!!
Howard
