Volvo Penta 1996 7.4 GL wiring
Rocky1985
I looked all over the web for a wiring diagram for my boat and wanted to share this with others looking for this information:
Ignition switch:
Red/blue wire (from 15 amp fuse) goes to terminal B (battery)
Yellow/red wire to S terminal (starter)
Purple wire to I terminal (ignition) then continues over to the safety lanyard switch
Starter Solenoid:
All red wires go to large terminal (9 o’clock position)
Large yellow/red wire from battery goes on large terminal (3 o’clock position)
Small yellow/red wire and orange wire goes on lower small terminal (6’ o’clock
position)
Purple wire goes on small upper terminal labeled ignition (12 o’clock position)
Two black wires are ground and go on bolts holding the starter solenoid in place
welcome aboard
the wiring diagram/schematic is in the factory manuals
wire color is standardized
