Gatekpr2002
- Jul 1, 2019
- 5
Hello everyone. I am having a problem with my engine hard starting while hot. Engine is Volvo Penta 2005 5.0 GXI-E 3809255, 4012156127. At the dock completely fine in the mornings while fishing and still a bit cool out engine starts fine hopping from spot to spot. Run for a while during day as the ambient temps rise harder to start especially when it was hot and humid a few weeks ago. The thermostat on the dash seems to be reading fine. After doing some research online I have found others with Volvo penta engines (not same as mine) with what seems to be very similar problems. They were pointed to the coolant sensor.
From what I can see on the schematics online there is a part #3850397 described as a switch, part #3852029 described as Sensor coolant water temp, part# 872068 described as a temperature sensor coolant water temp dual station.
I can not find out what parts do what or even where the parts are located if I even have all 3, I do not know.
The link below has the only schematics i could find.
Has anyone experienced a similar issue or can help in anyway?
Thank you,
Rob
Thank you,
Rob
