Hi,
I blew the Primary Drive Shaft bearing on my last trip. Everything I have read is that i can replace the bearing, snap rings, seal, etc. without pulling the motor. Most info out there is that the two-bearing drive shafts - the motor has to be pulled. If it is a one bearing drive shaft, I can fix from the rear of the boat.
I have pulled the outdrive, and I was able to pull the PDS right out the back of the boat. Still have to pull one Snap ring that is trapping the outer race of whats left of the bearing.
Can anyone point me in the direction of how to replace seals, bearings, snap rings and drive shaft for this set up.
