Volvo Penta 270 noise
Charlies XK22
We have a 1971 Chris Craft XK22 with the 350 Chevy motor and Volvo Penta 270 outdrive. Have noticed a grinding noise coming from behind the motor. It is a constant noise and was wondering if it could be the u joints or the enging bearings. Any thoughts?
captmello
Re: Volvo Penta 270 noise
Welcome!
Sounds like a cool boat! Also sounds like classic drive shaft bearing noise caused from water in the bellows. Unfortunately, pulling the engine is required to replace the bearings.
I would begin by removing the upper gear assembly. Here's how.
http://forums.iboats.com/showthread.php?t=309095
Once the upper is off, you can inspect the ujoints, and check the play in the drive shaft bearings.
This is a common repair, and despite the labor intensive job, it is not a difficult one, many of us here have done it ourselves with success.
