74bayliner
- Aug 23, 2011
- 607
Hi, I would like some help with this. I am taking my AQ 270 outdrive apart to reseal it and repaint it, the outdrive ran fine before it just looked like crud.. So i am ordering a few new parts. I have everything pretty much disassembled thanks to the workshop manual Don S. Provided in previous posts... Although I cannot figure out on the Lower part of the outdrive. How to get those gears out.. I read the manual I just dont understand. Is there some sort of tool i need? I know there is what looks like a lockwasher (like the one used for the propeller where you have to bend one of the tabs in... than a nut with 4 notches opposite of each other... But when i try to use any sort of tool to remove this nut after i bend the tab back out... it moves the Shaft... i cant hold it .. is there a technique or tool that i need?
Or can i just tape up the shaft in order to have the paint removed than painted...
Please let me know thanks.
-vlad
-vlad
