Volvo penta 275
davidklaus7
A friend using my boat damaged the prop by hitting it on concrete boat ramp. Also, on the top of lower unit where u check gear case oil , the dipstick amd approx. 3 inches around that was broken by a gear being pushed up. It will push back down to where the cover plate and 4 bolts with go together. What is supposed to keep that gear from coming back up as when I manually spin the prop , it will raise up about an inch. Is something broke or undone somewhere lower in the unit? Thanks. Dave
captmello
