Volvo penta 290 outdrive trim issue, square gauge.
dave7575
Hello
I have an issue with my 290 outdrive trim gauge indicating incorrectly. Hard to explain so I took a small Video of me trimming up then fully down.
https://youtu.be/J-INtLI8ZwY
As seen in the video the number display doesn't work and has never the time I've owned the boat. But just recently the red led jumps on when trimming up or down and stops the pump.
Any help would be much appreciated
David
alldodge
Unless and expert comes along I would say your trim sender has gone bad and needs replaced
kenny nunez
A D is probably right. I was at a Volvo school once and the instructor said that the guy who designed the trim sender and gauge must also design Pin Ball machines. We used to call the sender a YO-YO . The cable that goes through the transom plate to the drive always would bind and the spring in the sender was not strong enough to retract.
kenny nunez
I just realized that the 290 used a plastic gear on the top of the drive, The sender is corroded on the inside. Also inspect the wires coming out of the sender to make sure they are not starting to crumble.
The 280 was the one with the YO-YO.
since nothing is displayed, my gut feeling is the gauge itself is bad. Trim sender could be bad too (or the star wheel and gear segment that drives it). there are some NOS square gauges on ebay. the prices are way too high, however they are there. I had to replace mine 3 years ago for similar voodoo.
dave7575
Thanks. I'l check condition of the plug and wires to the sender.
dave7575
Thanks. I'll check the condition of the sender before replacing the gauge. Do you know if the gauge can be repaired ?
David
maybe 20 years ago. do a google search, maybe there is some mom-and-pop outfit that repairs them. I paid $125 on ebay 3 years ago for NOS.
dave7575
I removed the bolt from the securing plate.
Tried to withdraw sender but it hits the transom.
Have I missed something ? Is something else holding it in ?
thanks David
dave7575
thanks David
what is that goo all over your tiller arm?
dave7575
The grease was the problem. It passed the Internal o ring of the sender. I managed to get it free and open it up. After a clean with electrical spray cleaner it' reading steady on a multimeter. Thanks to for your help.
