The motor is a 2005, I've had it for 7 years without any major issues. Last week we headed out and about 30 myinutes into the trip at around 3400 rpms the motor stumbled and died. I was able to get it started after about 25 minutes but there was a miss and it would not idle.
I was towed home and it will turn over but will not fire. I have 12 volts at the ignition coil and spark on all 4 wires. The spark is orange but it will jump almost an inch to ground so I am not sure if it has weak spark since the color is not blue.
I changed distributor cap and rotor, new wires, new plugs and it will not fire over. I bypassed the kill switch lanyard and no change.
Fuel is squirting in the carb, and cylinder 4 showed signs of gas on it from the several attempts to start. Tried to start it with the gas cap open to see if it was the vent clogged up but no change.
It has to be something simple, but I am at a loss as my next step on troubleshooting.
