Hello all,
I'm looking to replace my manifold and risers on the boat this year very soon - this is a volvo penta 3.0 with sx drive.
First thoughts to give it a go myself a competent DIY attempt, Ive carried out all the other maintenance so far, gimble bearing, oils, starter, water pump etc etc.
So, any thoughts or advice someone can give me as to the procedure and torquing everything up as it should?
This engine has the Holley carb sitting on top of the manifold I believe (not local to the boat) - will there be any problems with setting this back up?
Finally, there is quite a significant cost difference between OEM and aftermarket parts, we all want genuine volvo here but is it worth it?
The current manifold and risers are around 7 years old used in salt water so expecting some form of rust.
Thanks!
Thanks!
