Volvo Penta 3.0 Sx | Outdrive nut size?
baker556
Hi fellow boaters,
Looking to take the outdrive off very soon before taking her out this season, just wanted to check, the six nuts on the outdrive what size are these so that I can source a replacement.
Many thanks!
baker556
dubs283
7/16 - 20 nylock shouldered nut
you can probably get away with stainless but the oem nuts are chrome plated brass
baker556
Hi Dubs283.
Thanks for this information.
I guess this justifies the cost from an online retailer then.
Is there a reason for using the brass type? To stop the nut from getting loose? Although the outdrive is submerged it's not like it gets overly hot.
Would stainless nyloc be up to the job?
Horigan
Stainless is fine. Be sure to put sealant on the studs per the manual.
dypcdiver
The studs are 20 TPI (threads per Inch) not Metric. and the nuts require a 5/8"AF Spanner.
baker556
thanks diver.
5/8 is the spanner size, that is a 16mm socket and the above-linked nut is M12 16mm - should that not work?
Just checked with local volvo they want £41 for these same nuts.
I need to find the right ones!
dypcdiver
No, that will not work. Studs ie, the ones the nuts go on, are not metric.
dypcdiver
So what you are suggesting is that you put put a 12mm nut on a 7/16 UNF stud, because it is cheaper.!!!!
baker556
Hey Dypcdiver you are right - I'm not fully clued up in the area of metric Vs imperial.
I thought if the pitch was the same it's possible this would work, obviously not.
I've found somewhere that stocks 7/16 - 20 but without the serrated part, would a standard washer suffice?
Thanks,
Chris
Horigan
I think a lock nut with just the nylon insert is sufficient. I seen that on other OEM nuts.
