Hello,
I am new to this forum. I purchased a boat about two years ago and was fed up with costly maintenence from the local mechanic. I decided to winterize the boat myself this year. When I was winterizing the boat, i used the DIY winterizing kit that hooks up to the muffs of the outdrive and sucks in antifreeze. While winterizing, i turned the water off and turned the antifreeze on and everything was going just fine. Also, there was white smoke coming out of the outdrive as it should. However, i've noticed a nasty burnt smell coming from the outdrive and the white smoke coming from the sides. I turned the engine off and checked the oil and there seemed to be no antifreeze or anything burning. Now, my question is, is it normal for white smoke to come out before fogging the carburator? Is it normal to have any sort of smell while winterizing? Please respond as i don't know if i just ruined my investment. :grumpy: Thanks.
