plainman98
- Jun 17, 2021
- 2
So I can't start the boat. No fuel going to carb. Tested pump with direct wire. It pumps. Tested relay with direct wire. It switches. Tested relay coil voltage with meter and when key turns on, it jumps to 2V, not 12 V. Bad Diode? Any idea what the diode looks like and where to find it? Diagram shows the orange wire feeds from a diode connected to the starter relay likely key activated. It appears that once started, the alternator green wire feeds power to the pump. It makes sense that the diode keeps the starter from activating while the alternator feeds power to the fuel pump relay, so I don't want to just remove it. I've been searching for more information on where it is located and what it looks like. Any information would be super helpful. Thanks!
