I have a 4.3 GL code 432BPLKD in a 1996 Chris Craft Concept 19. Last weekend we were out on the lake, stopped at a sandbar, when we went to leave we started the boat and went to get underway when the engine quit like it would if out of gas. Only thing is my daughter pulled the lanyard on the kill switch when the boat was off. I since have tested the switch with a multimeter and I have continuity.
I spent some time going through the forum and diagnosing. I found many threads by Don S where he shared a information on jumping around the relay to see if the pump runs.
Where I am now:
On the relay block I have 12V between 87 and 30, I can jumper to the pump and the pump will run.
No voltage between 85-86 with key on, key off, key on and cranking the engine.
Where does the power come from for the start relay power to the block 85?
What I found reading other posts, there is some discussion on a diode, where is that?
I have tested the neutral switch and the kill with, both have continuity.
Where to look next? I don't have a wiring diagram.
Its a great weekend for boating and here I am tracing down electrical problems! Any help would be appreciated.
Thanks, Tom
Where I am now:
Thanks, Tom
