chuongnino
- May 24, 2020
- 10
Hello. Thank you for your help in advance. I am a complete newbie so please pardon my lack of knowledge.
A little background: I recently bought a 1999 Larson boat that has a rebuilt V6 Vortec engine (originally 4.3 Volvo Penta) with a Volvo Penta Cobra outdrive. After the first outing, I have noticed several issues:
1. Engine is lack of power. At WOT I do not see it goes above 2500 rpm. I did check the spark plugs and they all looked bad. I replaced all 6 plugs but have not taken the boat out. Where else should I check for this problem beside the spark plugs?
2. Engine is overheating. The thermostat is not working so I could not tell what temperature it was operating at; but for sure over 200F. I suspect it is a water pump problem so I took the raw water pump apart to inspect. The impeller looks torn to me. Can you please tell me if the impeller and/or the pump are bad? I attached a photo for your reference.
3. After 1 hour of running around the lake, I noticed there was a decent amount of oil in the bilge area. When I run the engine on the muff, I do not see any leaking oil. Where should I check first for this problem?
Further inspection tells me that the exhaust bellow is torn. I ordered a new kit to replace both bellows and gimbals bearing.
