99FourWinns
- Feb 17, 2014
- 5
Hi everyone I am new to this, so I hope I am posting correctly. I recently acquired a 99 Four Winns horizon 170 with a 4cyl Volvo penta I/O. An inspection report was done, and I wanted to a get a little help on finding a solution to some of the issues.
The report says that it idles well and runs rough (due to carbs needing adjustment). The compression is as follows;
1- 185, 2- 165, 3-120, 4- 125. Note says frost plug on water jacket was out and it has been pounded back in. The cooling system was tank tested, and it said it starts to overheat, and has a weak water pump and tell tail. It is currently winterized.
*I have attached the full inspection link*
http://https://www.dropbox.com/s/a3p7kwntqqrm9ge/1234712.pdf
I have done many repairs on cars but this is my first boat, so any help on knowing where to start and what may be causing some of my issues would be great. Thank you.
