Volvo Penta 5.0 Cross Referencing to Sierra Parts Help
riden
Hey guys
My son has a 2008 Volvo Penta 5.0
His birthday is coming and I would to order him a dist cap, plugs, wires, water pump rebuild kit etc. and help him put it all on, even if it has to wait till Spring to do the work.
I live in a remote rural location, so there is no dealer to help me out. I would like to order Sierra parts because they seem a good price ( open minded to an other choice) but I just can't figure out which parts exactly.
Can anyone recommend a site I can cross reference or a simple site I can order parts from and be certain I am getting the right parts. Ideally I would like to order everything online.
Thanks in advance.
muc
"Retired" Association of Marine Technicians...
At the top of this page, click shop.
To get the right parts, I recommend that you start with the engine serial number-best, engine product number-good or engine model number-might work.
Go to the OEM Volvo parts lookup on this site and get the Volvo part numbers. Due to my years as a marine tech, I recommend you buy these parts.
But I understand some people think they can save money buying cheap aftermarket parts. If this is what you want to do, cross reference the Volvo numbers to Sierra or other cheap might fit parts supplier and order.
This will increase your chances of getting the right parts.
I recommend that you wait until right before your son is going to use the parts to order them. This way if something goes wrong, he will be able to return them.
Maybe give him an iBoats gift certificate?
riden
Thanks for the advice, it's solid. But I am in Canada and Volvo only accepts US customers.
I was on the Volvo site before and I found it just misery to use, perhaps this is why.
muc
Didn’t know there was a problem with our friends up north.
When I log into the dealer portal it’s always to Volvo Penta North America. So I assumed that it would work for Canada. I have learned to call tech support later in the day, because I would get someone in B.C. and they were always knowledgeable and helpful.
Maybe try searching for Volvo Parts Canada to get a site that works for you.
All the manufacturers parts sites can be a bit difficult to learn at first. This is because they have full information. Trust me, you don’t want to use an aftermarket site to look up parts.
alldodge
Not going against ya muc, but these are ignition components. I would not recommend Sierra nothing, but they are GM parts
Might be able to get those parts from the local GM dealer other then the wires and water pump kit. The water pump kit should be a shearwood but don't know which 5.0 it is
muc
I agree that Volvo doesn’t make the majority of these parts. Part of what you pay for covers the 1 year (2 years if purchased and installed by a dealer) warranty. But part of it pays for the Q+A that they do on the incoming parts. They reject up to 30% of parts they receive. Those parts are returned to the manufacturers and sold to someone else. For the average person I do believe there is value in buying OEM parts.
I do know that on certain parts you can get a better part aftermarket. For awhile Mallory was making a flat top distributor cap that was better than OEM. But because of the inconsistency of aftermarket parts, you really need the knowledge, experience and test equipment that the normal person doesn’t have.
Along time ago, there were a couple of years that I preferred Sierra inner transom shift cables. Even though they were having a issue with the shift slide (easy to see with the naked eye) because they were better. Mercury caught up and passed them. But I wouldn’t use their bellows even if they were free.
My advice is go OEM unless you’re qualified to know the difference. I can’t count how many times I’ve replaced a brand new part that the customer had replaced themselves and had gotten it from GM, FOMOCO or the auto store.
billbayliner
Volvo Penta will let Canadian I.P addresses into their site now and you will have access to the exploded views.... You need to look at the tag on the the engine valve cover and then can track down every part number for the engine and drive.... Some google searching will allow cross reference numbers....
Here are some raw water pump cross reference numbers...... :)
804959 is Jabsco model # 9400-0001 pump
807368 is Johnson model # 10-35157-3 pump
820694 is Jabsco model # 10770 Series pump
822787 is Jabsco model # 10770 Series pump
825916 is Jabsco model # 9900-0001 pump
826456 is Jabsco model # 22740 Series pump
828026 is Johnson model # 10-32621-2 pump
829895 is Johnson model # 10-35098-3 pump
831178 is Johnson model # 10-32058-1 pump
833415 is Johnson model # 10-35157-3 pump
833522 is Johnson model # 10-35157-3 pump
833883 is Johnson model # 10-35157-3 pump
836326 is Johnson model # 10-22335-3 pump
837370 is Johnson model # 10-24017-3 pump
837371 is Johnson model # 10-24017-4 pump
837915 is Johnson model # 10-24017-4 pump
837916 is Johnson model # 10-24017-3 pump
837917 is Johnson model # 10-21915-2 pump
837920 is Johnson model # 10-21915-2 pump
837922 is Johnson model # 10-24017-4 pump
837923 is Johnson model # 10-24017-4 pump
838314 is Johnson model # 10-24061-4 pump
838522 is Johnson model # 10-24130-2 pump
840557 is Johnson model # 10-24178-2 pump
841860 is Johnson model # 10-24228-1 pump
842274 is Johnson model # 10-22335-4 pump
842275 is Johnson model # 10-22335-4 pump
842843 is Johnson model # 10-24061-3 pump
844971 is Johnson model # 10-24130-3 pump
846354 is Jabsco model # 10770 Series pump
846355 is Jabsco model # 10770 Series pump
846356 is Jabsco model # 10770 Series pump
855517 is Johnson model # 10-32621-2 pump
855578 is Johnson model # 10-32621-3 pump
856952 is Johnson model # 10-24228-1 pump
857451 is Johnson model # 10-24228-1 pump
858065 is Johnson model # 10-35157-1 pump
858150 is Johnson model # 10-24268-4 pump
858408 is Johnson model # 10-24268-5 pump
858469 is Johnson model # 10-24277-3 pump
858470 is Johnson model # 10-24277-4 pump
866739 is Jabsco model # 10770 Series pump
3829310 is Jabsco model # 10770 Series pump
3829311 is Jabsco model # 10770 Series pump
3852398 is Sherwood model # G9901 pump
3852399 is Sherwood model # G9902 pump
3855079 is Sherwood model # G9903 pump
801277 is Jabsco model # 920-0001 impeller
803729 is Jabsco model # 4528-0001 impeller
804696 is Johnson model # 1026B impeller
807904 is Jabsco model # 836-0001 impeller
818680 is Jabsco model # 4598-0001 impeller
825940 is Jabsco model # 1210-0001 impeller
825941 is Jabsco model # 920-0001 impeller
825942 is Jabsco model # 836-0001 impeller
831182 is Jabsco model # 4568-0001 impeller
833550 is Jabsco model # 42528-0001 impeller
833995 is Jabsco model # 22405-0001 impeller
834794 is Jabsco model # 22120-0001 impeller
835182 is Jabsco model # 4568-0001 impeller
835512 is Sherwood model # 9959K impeller
835874 is Sherwood model # 10615K impeller
842857 is Johnson model # 802B impeller
844683 is Johnson model # 802B impeller
845796 is Johnson model # 802B impeller
860203 is Jabsco model # 1210-0001 impeller
875573 is Jabsco model # 4568-0001 impeller
875575 is Jabsco model # 4568-0001 impeller
875583 is Johnson model # 808B impeller
875593 is Jabsco model # 920-0001 impeller
875660 is Jabsco model # 836-0001 impeller
875697 is Jabsco model # 17936-0001 impeller
875807 is Jabsco model # 4528-0001 impeller
875808 is Johnson model # 1026B impeller
875811 is Jabsco model # 1210-0001 impeller
897055 is Johnson model # 1026B impeller
3854286 is Sherwood model # 9959K impeller
